Keyboard Making Clicking Sound
Discussion in 'Huawei Ideos S7 Apps and Games' started by zuc, Dec 15, 2010.
  1. zuc
    zuc Member
    NULL
    I looked through a few pages of the forum, but didn't see a similar post so I have to create a thread.
    As the title says, the keyboard makes a clicking sound when I type. How can I quiet it? I looked into the Settings, but no help from there.
    Thank you
  2. pbrauer
    pbrauer Administrator Staff Member
    Edina, MN USA
    Should be in Settings->Language & keyboard->Android Keyboard and there is a check box for sounds on keypress. Did you actually go to the menu for the keyboard itself?
  3. zuc
    zuc Member
    NULL
    Thank you for the quick reply.
    I am there. It's unchecked.
    Maybe I should check it and find out.
  4. zuc
    zuc Member
    NULL
    Got it.
    It's not "Sound on keypress" under Android keyboard. It's actually "Keypad tone" on/off under Huawei IME settings.
    Thank you
  5. pbrauer
    Edina, MN USA
    glad you worked it out, I use the Android keyboard not the Huawei IME so I didn't check that one.
    Cheers,
    P
  6. JackJack
    JackJack Member
    US
    N/A
    Btw: try Swype IME, a good IME.
  7. Triune
    Triune Member
    NULL
    I got that also and by accident dropped the tone level to zero when typing, and that also stops the sound
  8. pbrauer
    Edina, MN USA
    You have to go all the way into the settings specific for the Keyboard, not just for Language & Keyboard to see where it usually is. also, if you are using a custom or non-standard keyboard it may be someplace else entirely.
    You can also check your Sound Settings, you may have a Silent Mode setting depending on your device type and configuration
how do I get a keypad in a huawei tablet
how do i make the huawei phone keyboard to be silent
how do you get your keyboard to click on a alldaymall tablet
how to silent of a tab keypad
huawei keyboard sound
huwei phone keyboard sound
keypad on htc makes annoying clicking noise
sony tablwt keyboard sound
tablet clicking sound
why does mt tablet make clicking sound
