Kindly help me
Discussion in 'Android Tablet Q&A' started by kruthikbeats, Feb 14, 2012.
  1. kruthikbeats
    kruthikbeats Member
    http://imageshack.us/g/406/img0779p.jpg/
    this pad was gifted to me by my friend when i was in China ,the thing is i used it 2 or times in china bt unable to get connected to wifi..after iam bak to India i opened it today and switched it on ,open screen came later " android screen came" datz it blacked out...kindly tell me the procedure....and iam newbie so kindly help me out from basics..thanks in advance
  2. Tanzanite
    Tanzanite Senior Member
    Tanzania
    10' Android 4 Tablet
    Hi Kruthik,
    It is difficult to tell what exactly has gone wrong but most Tablets have a reset bottom somewhere which you can reset the tablet with and hopefully it will start up again.
    Try to look for a little hole where you can use a small needle to reset the tablet.
    Good luck
  3. Spider
    Chicago, IL
    Hi Kruthik, congratulations on your new tablet and welcome to the forum. I'm moving your thread to the Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
