Kyros vs. iPad - same chip!
Discussion in 'Coby Tablets' started by Radioman55, Jun 11, 2011.
  1. Radioman55
    Radioman55 Member
    Coby MID7024
    Just got my MID7024 from Best Buy. I was doing some reading about processor chip (Soc) that is inside, and it seems as though the 7024 has basically the same chip as the first Gen ipads... and this for around $170! I got this quote from a tech blog:
    Although the documentation never refers to the Coby chip as a "Hummingbird" (nor did Apple in the 1st gen ipad), the chip utilized by the 7024 is a 1 GHz Cortex A8 (just like the Hummingbird) and was "developed by Samsung with Intrinsity" (just like the A4); so it seems to me the 7024 has basically the same chip in it that's running the first generation iPads, yet for less than 1/3 the cost!
  2. Sketch_Says
    Sketch_Says Member
    Jacksonville, FL
    Coby Kyros MID7015 4G
    This actually makes quite a bit of sense. As you may have read already, Tipstr found a full fledged OS IMG of android 2.3 from the Original Manufacturer of the Kyros 7015 (not Coby). Since reimaging the Kyros 7015 to 2.3, I've noticed that, while testing the flash capabilities, some websites recognize/think that the Kyros is an iPad. Based on what you've listed here, that seems to explain the cause. Good read. Thanks for sharing.
  3. Radioman55
    Radioman55 Member
    Coby MID7024
    Glad I could help! So you got 2.3 running on your 7015... Do you think I could get 2.3 on my 7024?
  4. Martian59
    Martian59 Member
    Coby MID7015A
    Where can a MID7015 download this 2.3 image, success reports and instructions on how to install it?
    Thank you.
  5. Radioman55
    Radioman55 Member
    Coby MID7024
    He said it was on Tipstr.
  6. sercero
    sercero Member
    Argentina
    Coby Kyros MID 7015A
    Hello,
    The fact that the web sites recognize the coby kyros as an iPad device has nothing to do with the processor.
    When you visit a web site the browser sends the site and identification string so the site can send a custom made html and the browser can reender correctly.
    I think that it has been discussed already in the forum that the reendering engine of android browser is webkit which is the same as safari of apple so it makes sense that it identifies itself as an ipad due to the popularity of the later and having many sites tailor made for it.
  7. kentever
    kentever Member
    Texas
    Coby MID 7015 and Acer Iconia Tab a100
    I have searched on Tipstr and cant find anything about 2.3 for the 7015 could someone help me out with a link or dummy directions to it lol. Thanx
  8. kentever
    kentever Member
    Texas
    never mind i found it
  9. Radioman55
    Radioman55 Member
    Coby MID7024
    Sercero - That makes sense, especially since my original post was in reference to the 7024 and Sketch has a 7015, thanks for the info.
    Kentever - Glad you found what you needed.
