Lyrics and backing tracks player for singers
Discussion in 'Android Tablet Audio' started by Denidog, Nov 27, 2011.
  1. Denidog
    Denidog Member
    NSW, Australia
    Acer A500
    I've been using my laptop to display my lyrics and, at the same time, play my backing tracks. (Yes I'm a singer). I achieve this using MSpowerpoint. I put the lyrics on a slide and embed a trigger in the slide that, when clicked, will start playing the music.
    Now I've just purchased my first Android tablet and downloaded a documents app. Whilst it will play the Powerpoint file the music trigger won't work.
    Has anyone solved this problem?
    I've had a look at a few karaoke apps but can't find one that will allow me to load my own lyrics. Does anyone have a suggestion?
    Any help will be much appreciated.
    Ellis.
    Sharing the joy of knowledge.
back track music player for singers android
backing track application for android
backing track for tablet
backing track player app android
backing track player with lyrics android
backing track with lyrics app android
best backing track player for android
best backing tracks player for tablet
best tablet to play backing tracks
downloading backing tracks onto a tablet
how do you use a tablet to run backing track for singets
how to use a tablet for backing tracks
lyrics and backing tracks on tablet
lyrics on android tablet
play lyrics and backing tracks
playing backing tracks on a tablet
playing backing tracks using a tablet
tablet for playing tracks
using a tablet to play backing tracks
