Micro SD Card Problem Coby 7015
Discussion in 'Coby Generation 1 Technical' started by dimwit, Mar 16, 2012.
  1. dimwit
    dimwit Member
    Coby 7015
    Forgive me if this has been answered before, I searched for a solution. I can read the SD card fine in a USB card reader.
    I thought I had already solved this problem last night. My Coby tablet saw the card and all files correctly, then today I turn on the tablet and back to blank or unsupported. (Same SD card, no changes made to it, no updates, I did not touch the SD card once my tablet read it again. I tried to format the card yesterday on the Coby but it removed nothing.
    Any advice or troubleshooting help? Thank you.
  2. dimwit
    dimwit Member
    Coby 7015
    During trying to do a factory reset I have some more information.
    ClockworkMod Recovery 2.5.1.3
    Can anyone tell from this what the problem is? Thank you for looking.
  3. dimwit
    dimwit Member
    Coby 7015
    I guess this is solved. I took my card out of my Coby, formatted it in the USB reader on my computer, and now the 7015 reads the SD card.:eek:
all updates for coby7015
cwm recovery error no app2sd partition found
format micro sd card for kyro tablet
no app2sd partition found error
