philth28
- May 24, 2013
- 3
- 0
Heres how fixed mine after refusing a refund from T**** who said it couldn't be fixed.
Frst using the usb cable that came with the unit, others tend to be short in the bayonet department that fits the unit,switch on the tablet and change setting to stay awake while connected and leave it to totally discharge 4-6hrs,when it switches off abruptly you will see multi colored static continually flash on the screen, the small charge from usb tries to keep it alive,when this occurs switch off usingpower button on the tablet and remove usb and then plug in ac power plug to recharge!
Switch back on and check to see battery monitor graph should be working and a warning its low on power should work.
