HI! I only can use my FlyTouch when the charger is connected. If I take out the charger, the device turns off. In the device, the battery state is 100% ! Please help me Add me on msn! mathiasranellucci@hotmail.com !PLEASE! TNXS Help me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You really must stop opening multiple threads on the same issue. It's a great way to get ignored! And often banned! Sent from my Ideos S7 using Android Tablet Forum App
Not much anyone can do if the battery has issues charging. Also could be your power supply unit going bad. I would get a multi-tester to check it out first to see what's going on you. Also the OP needs to have one post and don't repeat the same posting all over again.
