Noob with Coby MID-7048-4G Needs Help
Discussion in 'Coby Tablets' started by BigDaddyG, Oct 1, 2012.
  1. BigDaddyG
    BigDaddyG Member
    Apex, NC
    Coby MID7048-4
    I just got a Coby MID-7048-4G for my wife and realized quickly that it is severly crippled by the manufacturer - with the main problem being no Google Play Store, so I am stuck with the limited apps on GetJar.
    I installed Google Play Store using APK recommended on a post on this web page, but I couldn't get it to work - it just kept autoclosing immediately after I launch it. I finally just deleted the app.
    I also "upgraded" the Office Suite of apps that came pre-installed based on a system prompt, but the "upgrade" was to version that is not free and I cannot revert. I was going to reset to factory settings, but I am not sure if this will wipe the tablet completely with no apps at all, or just revert to the way it was when it came out of the box. Logic dictates it should be the latter, but the wording on the tablet implies the former.
    Finally, I can't find a decent thread on how to root the device so I can control the apps myself. I am not even sure what generation the device is considered to be - I assume 2, but have no way to tell.
    Any help with these issues would be greatly appreciated.
  2. Samsungaholic
    Samsungaholic Member
    Canada
    Samsung, Coby
    Got one too yesterday. This thing is as good as a paperweight. Not only you cant load anything of value, but you are totaly limited to the get GetJar, a play store cheep imitation.
    I do not suggest anyone ever buy a Coby , it is just a waist of money.
    This thing looks good on paper, but it looks like the company decided to limit the software. The dvi port could have been used, but there is NO netflix or cracle ... so you can only play stuff like you tube on your TV.
    If I had a note on 10 for this device, it would probably be a 1/10
    Tried all the plays tore hack ... none of them would work on this device.
    No answer from the Coby tech support too...
    Conclusion STAY AWAY from Coby... it's cr@#e
  3. Samsungaholic
    Canada
    Samsung, Coby
    BTW. if you need any apps... try http://m.aptoide.com much better than GetJar
    They also force you to find pirated files like here... http://www.filecrop.com searche for .apk... but beware of virus... get yourself a good anti-virus first... Good luck
coby kyros mid7048 after data wipe
coby kyros mid7048 google play
coby kyros mid7048 install google play
mid 7048 manufacture assistance
mid7048 manufacturer assistance
netflix on coby kyos 7048
tablette mid7048 apps
