Im in the uk and just brought the PIPO U1 from china. The tablet came with a wall plug charger but its only 2 pin in the UK we have 3 pin. Does anyone know a suitable wall charger to buy, as charging through USB takes hours.
Where did you buy your Pipo U1? The seller is unprofessional I think. In my opinion, you should buy a charger in the local store, or you can buy one from Amzone or eBay. Because it will take a long time if you buy one from China online store.
