Please Help
Discussion in 'Android Tablet Discussions' started by Codynah, Nov 28, 2011.
  1. Codynah
    Codynah Member
    Indiana
    Pandigital Planet
    I just purchased a Pandigital Planet and have forgotten my pattern password!! I have been locked out of it for 2 days and I am going crazy! Does anyone know how I can reset it or something to get back into in???
  2. ObsidianBlk
    ObsidianBlk Member
    Connecticut, USA
    Acer Iconia a500
    Unfortunately, the easy way is to reset your tablet to factory, which means you'd loose everything installed on it. There may be another method, but it'll be complicated. Truthfully, though, its best that way because if it was easy to bypass a lock without loosing your data then the lock would be worthless.
  3. Beerbreadlover
    Beerbreadlover Member
    Delaware, OH
    Pandigital Planet
    Do you know how to reset the tablet to factory? I don't care if I have to reinstall all the apps I downloaded, just want to be able to use it.
  4. jdub922
    jdub922 Member
    ROLL TIDE
    Acer A500 - stock
    Copied from a Google search:
    " with the unit off hold the +volume button and hit the power button let go of the buttons. the screen will look like it booting up you will get a promp screen. use the +volume button to scroll thru the list. to factory data reset. then use the -- volume button to enter. the unit will reset it self to factory settings."
    Sent from my A500 using Android Tablet Forum, and ROLL TIDE.
factort reset pandigital planet tablet
fbi locked my pandigital tablet
forgot lock pattern on pandigital tablet
forgot screen lock password for pandigital tablet
how do you reset a pandigital tablet to factory reset if screen cracked
locked out of pandigital tab
pandigital planet lockup
reset pandigital tablet locked
