I bought and reconditioned Disgo 6000 but the included charger is too big to fit. Does anyone know of a replacement charger that can be bought in the uk?
Can you confirm the dimensions of the DC Power Jack in the Disgo 6000 is the same as the Sylvania?
2.4mm OD "Outside Dimension" X .75mm ID "Inside Dimension" PLUG
This is a 2.4mm OD x .75mm ID , two-prong leads detachable plug for connection to many universal AC/DC adapters with removable tips. Many universal AC/DC adapters that can be set to the correct voltage.
Digital Gadgets - Tablet FAQ identifies the voltage and amperage.
Q: What is the voltage and amperage of the charge adapter?
A: Input: 100-240V~0.65A, Output: 9V
Assuming both the power jack dimensions and the Input/Output voltage specifications are the same any universal adapter that includes the proper size jack and that can be set to the proper voltage/amperage will work.
You'd be taking a risk without actual measurements since pictures L, M, and T all seem to be similar but could be different sizes.Hello all (especially cfrockit) do you know if any of these adapters is equivalent to the one on the disgo 6000 I am thinking it may be possible to use this adapter with a solar powered charger to extend the battery life of the device while out and about
Auctiva Image Hosting
thanks
