S7 -104 will not power up after flash
dfj
I have a Telstra T-Tablet Huawei S7-104 with external SD . I wanted to update to 2.2 . I downloaded instructions from this site , and allwas going well.. First pass, white bar completed and said ok. Removed battery , replaced battery and powered up, white bar started to progress to about half way, then unit turned off, and will not show any signs of life. I have changed battery , but still will not start or eevn flicker. Totally dead. Has any one got any ideas? Many thanks
vkcpolice
hi i had the same prob i just tried to upgrade mine to android 2.2 and it wont power back on either seems like the device is dead if you managed to fix this prob then please email me at [email protected] im so upset just spent a fortune on it and its rooted in one day
