Softwinerevb Low Voltage/USB Issue
Discussion in 'Android Tablet Q&A' started by sid79, Jan 3, 2014.
  1. sid79
    sid79 Member
    maidstone
    softwinerevb
    Hi guys,
    I've been searching for a solution to this problem and found nothing.
    I bought my son a tablet for Christmas and its got a power issue.
    Its a SoftwinerEvb
    Android version 4.1.1
    Baseband version v0.4rc3
    Kernel version 3.0.8+ android6@linux2#238
    Build number nuclear evb-eng 4.1.1 JRO03C 20130628 test-keys
    The problem is when the battery is at 40% a low voltage or power warning pops up and says to close the usb port. Tapping the warning does nothing, and I can't find anything in the settings to close the usb port! It then turns itself off with 30% battery left.
    He gets so frustrated when he's only been using it for about half an hour for it to go on charge again.
    Any ideas gratefully received.
    Thanks, sid
android device low voltage or power
low voltage or battery close the usb port
low voltage or power android
low voltage or power close the usb
low voltage or power close the usb port
low voltage or power close the usb port android
low voltage or power close the usb port android spanish
low voltage or power in android tablet
Tablet close the usb port
why my dragon tablet keep saying low voltage
