Superpad 3 screen problems
shishko
I just received "Flytouch 3 Superpad 3" tablet (X220, 512 MB, 4 GB, single TF slot, supposed to be DISCO10 model), but have problem. When I power it on, it vibrates and after something like 30 seconds I hear a startup music, but screen remains black all the time.
When I unlock it by pressing menu for 5 seconds and touch the screen, I hear clicks like I'm clicking on icons. So I believe touch screen is working, but there's absolutely nothing on screen.
Any ideas?
Denis
smokerau
hi shishko i am having same problems on and off can you give me instructions on how to took the screen off thanks
smokerau
hey shishko here is front and back pics its the one with the flat black backing ok $tablet back.jpg$tablet front.jpg
zakiaw
i also have similar problem. There was no display at all after leaving my pad ON overnight. I believe my pad was running as it was responsive when i push on display (by producing sound). The screen not showing anything even after i re-flash the rom. COuld this be caused by the ribbon cable also?
