tablets and a stylus?
Discussion in 'Android Tablet Q&A' started by steelbender, Jan 17, 2012.
  1. steelbender
    steelbender Member
    NW PA
    EGlide 10 XL
    Hey all, My Ematic Eglide 10" XL is arriving soon. Nowhere in the online info does it say if a stylus can be used on the screen (TFT type). Anyone know???
  2. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    You will need a capacitive stylus if you have a capacitive screen. It is kind of a mixed blessing, they work but are not very precise.
    Sent from a Gibson using Tapatalk - heavy metal edition
  3. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    The one made for iPhone and iPod (the one with a soft rubberlike tip) works on both Resistive and Capacitive screens.
  4. steelbender
    steelbender Member
    NW PA
    EGlide 10 XL
    great, thanks
  5. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    Actually anything you can apply pressure with will work on resistive screen.
  6. steelbender
    steelbender Member
    NW PA
    EGlide 10 XL
    I take it they are resistant to scratching? Hate to damage it....
  7. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    I recommended the iPod one because it has a soft non scratch tip. If you have a resistive screen almost any (plastic) stylus, as TomT says will work.
  8. steelbender
    steelbender Member
    NW PA
    EGlide 10 XL
    that's fantastic...thanks for the input...
  9. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    Yeah, the soft tip is fairly safe, the main fear I have is if there is dirt or something on the screen there is the possibility of putting pressure on it with the stylus and scrtching the screen that way. I usually just try to clean my screen well before using the stylus to minimize the risk. I think if I were going to use a stylus as my primary input method I would apply a screen protector.
  10. steelbender
    steelbender Member
    NW PA
    EGlide 10 XL
    I doubt that a stylus will be the main input method, but probably quite a bit. A screen protector sounds like a good idea regardless.
