Using USB Port for Counting Things or Timing Things
Discussion in 'Huawei Ideos S7 Slim Technical' started by Music, Feb 4, 2013.
  1. Music
    Music Senior Member
    Northcoast, OH
    Google Nexus 7-13, 32 Gb
    Is there any way you can connect some wires to the Micro USB port with either a pushbutton or micro-switch, in order to count something, like if you pressed a pushbutton or a microswitch? Another use would be to record the time the switch was pressed.
    I read about something called an IOIO board, but the company building it gave up on the idea a few years ago. I don't need any fancy IO, just a way to connect a switch or microswitch
    thanks.
