Audio problem
Jasonpwms129
​My daughter recently got a Vizio tab, and after loading music onto her SD card and mounting to
tablet, when she plays it, it sounds choppy and almost like its skipping.
:confused: Used the main player,
and a few that I downloaded off the Market, and they all do it.
:mad: So I removed the ones I dl'd.
Not sure whats up. Any help would be great.
Not rooted, current software.
I don't have this problem. The only thing I can think of is the SD Card read speed might be too slow. Do you know what class it is?
Secure Digital - Wikipedia, the free encyclopedia
maybe your audio files aren't compatible well with your tablet, i think you should figure out your tablet supported audio formats, then you can use foxreal video converter to convert your music to the audio format that your tablet likes, the audio conversion function of this tool is free
