P Proka Member Dec 27, 2012 1 0 Dec 27, 2012 #1 Should I buy [FONT=Arial, Helvetica, sans-serif]Onda V972 or Hyundai Play X (x900)? I will use, primary, to surf the web. I need device which runs smooth.[/FONT]
cali Super Moderator Staff member Sep 25, 2011 689 94 Dec 27, 2012 #2 Welcome to the site. Suggest you try each at a retail store to see which seems better to you.
