M701-R and Universal Remote?
S87
91
7
Has anyone tried using a universal remote with the M701-R? Just wondering if it used standard codes before I try punching a thousand buttons to see if one code works.
I was hoping that a higher-powered remote might work better when it's hooked up to the TV.
I doubt it uses any standard remote control codes. But if you have a "learning" universal remote you should be able to program it to replicate the remote's signals (I'm talking about the universal remotes where you point the device's remote into a sensor, press a button, then press a corresponding button on the universal to program it).
