Alkido won't work
Discussion in 'Coby Tablet Apps and Games' started by AnneLise, Oct 11, 2011.
  1. AnneLise
    AnneLise Member
    Quebec
    I got a 7024 but I guess they're maybe the same regarding apps...
    Alkido was already in the system when I bought it and it worked great for a while. Now though, when I open it and click on the book I wanna read, it starts loading but shuts down and goes back to the shelf view after few seconds. It is impossible to read any book on Alkido.
    I tried uninstalling it but I can't as it was already in the system, I tried to install it again from applibs and doesn't work either.
    I just use ebook Reader and B & N now but they're not the same.
    What do you suggest?
  2. lfom
    lfom Senior Member Developer
    Brasil
    First, you are in the wrong section of the forum. 7024 is Kyros 2nd generation. ;)
    Coby Generation 2
    About Aldiko (I think you misspelled it), then version 2.0.2 is broken in Kyros for some reason. If you have Market installed, it will auto-update it, you must disable it first and then uninstall updates. The latest version that works is 2.0.1, factory built-in version is 2.0.
