Android 2.2.2 for Huawei S7 rear-facing camera ????
Discussion in 'Huawei Ideos S7 Technical' started by zax5bg, Apr 24, 2011.
  1. zax5bg
    zax5bg Member
    Bulgaria
    Huawei S7
    Hi,can you help me ,to find Android 2.2.2 for Huawei S7 rear-facing camera ????
  2. skoster
    skoster Member
    Maryland
    Rear facing cam works fine on mine with the Indonesian 2.2 I got from this forum. I have the Best Buy 2 camera S7.
  3. zax5bg
    zax5bg Member
    Bulgaria
    Huawei S7
    mine is with one camera ,ant no worck
  4. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    After the upgrade, you did go into settings > camera, and set rear as default? or try one then the other? reboot after each change? just making sure, not sure if it matters.
    Sent from my IDEOS S7
  5. zax5bg
    zax5bg Member
    Bulgaria
    Huawei S7
    I cant finde - camera setings in the settings menu
  6. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    Hmmmm when i click on settings it's the the 5th one down.
  7. rictec
    rictec Member
    here its the 5th down too just after display (visor in PT)
  8. zax5bg
    zax5bg Member
    Bulgaria
    Huawei S7
    There is no such a setup, I'm using HUAWEI S7 model 101. My fifth setting is - Location & Security, then update to 2.2.2 does not change.Found solutions here-http://4pda.ru/forum/index.php?showtopic=233383, ЗАПУСК КАМЕРЫ на Life:) планшете subject is in Russian, but with the help of - Google translator i made ​​it.
  9. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    Glad you got it fixed for your s7
  10. zax5bg
    zax5bg Member
    Bulgaria
    Huawei S7
    Tanck you
how to enable back camera on huawei tab
huawei s7-791u
