Boot loop problem after rooting
Discussion in 'Coby Tablets' started by MaskedTurtle, Dec 24, 2011.
  1. MaskedTurtle
    MaskedTurtle Member
    I have recently tried to root my Kryos MID7012-4G with SuperOneClick 2.2. After I successfully completed the process on my computer the tablet restarted as it should. But when it tried to reboot it can't do it. It reruns the Android loading screen.
    What should I do to fix it, wait longer to see what it does, or I just screwed it up.
    Thanks for your help.
  2. Raila
    Raila Member
    Coby Kyros 7012-4G
    I had the same problem with mine when I first rooted it. Stuck on the Android screen and just kept looping. I hit the little Reset in the back, let it reboot, had to re-root again and all was well
    Good luck!
  3. CaseyP
    CaseyP Member
    United States
    MID7012
    I've done that about 16 times, same results.
    I had it rooted, I am selling it to a friend so did a factory reset, and now it just boots to the android loading screen. I have wiped the cache and did a bunch more factory resets. it boots to the android screen, and I can't turn it off. all I can do is hit the reset button in the back, and it boots back into the android logo, loops forever.
    Any advice on how to get this thing back to factory home screen?
  4. CaseyP
    CaseyP Member
    United States
    MID7012
    I'm thinking that if I can find a copy of the stock rom I can use the "update from SD card" option...what do you guys think about that? and any idea where to find a copy of the 7012 image?
  5. popmartin
    popmartin Member
    Coby MID7012
    Hi I have a Kyros MID7012 with the same problem , except all i get is the android screen. when i tried the factory reset it didn't do anything still stuck on android screen. Now when I try reset button it only goes to fastboot screen and I have nothing to install with fastboot. Any recovery image available? It was in usb debug mode before it crashed. It crashed because i uninstalled something that should not have been uninstalled. Anyone have any idea what to do with this besides using it for a paperweight?
  6. bigfordman03
    bigfordman03 Member
    Alabama
    Coby Kyros MID7024 and Pandigital Star
    Well your gona have to reset the system more likely or if you cant do that then you jacked it up so tip to people don't root your devices its very riskful that's what happens.
  7. ntoy1
    ntoy1 Member
    Hello,
    Newbie here. I have an Ematics egs114 tablet that will not boot. Does anyone happen to have the rom file?
    Thx
After i tried to root my nook hd it is looping at nook startup
android 6 boot loop after rooting
android boot loop after rooting
android tablet problem in bootloop
bootloop after rooting android
devante fastboot mode
how to root andraoid phone sun a710
pattran devanate tab
saycool tablet rebooting issue
sun a710 hard reset
