Failed firmware flash - system dead
Discussion in 'WonderMedia WM8505 Tablets' started by shopalath, Nov 4, 2010.
  1. shopalath
    shopalath Member
    NULL
    I started to update the firmware of my (so called) MID FY-706 (MID 706) pad.
    During the installation process an error happened: "...can not mount file system - exit!" (during the second screen of messages).
    After 30 minutes of waiting I powered down the device.
    Since that pressing the power key takes no effect (short, long, very long pressing)!
    The screen is black, no message, no icon, no boot screen.
    I can see that the green power LED is turning on (immediately), but thats all.
    Pressing the reset button in any combination with the other keys takes no effect.
    Connecting the external power source switches the power LED to red. The device ist getting warm and the rechargeable battery is beeing loaded.
    Switching the system on (green LED) is discharging it.
    Inserting a SD card with a firmware script will not start any update process.
    I did approx. 20 trials to re-flash my device this day. Was that too much?
    It started with:
    http://www.androidtablets.net/forum/via-based/573-restore-fw-mid-706-ly-706b-2.html#post11742
    Is there any way to reanimate this dead device?
    Thank you.
    Look at the pictures to find out which device I have...
    Device: generic
    Android 1.6
    Build 1.9
    256MB RAM
    (also posted in SlateDroid.com)
  2. rodolforomano
    rodolforomano Member
    NULL
    I have the same model and the similar problem!! The screen is black, press power the light is on but not appear in the screen. put script in scard and nothing.... how to recovery ?
  3. sdpinsens
    sdpinsens Member
    NULL
    I've got the same problem too...my device,at the first time can boot,but untill the booting was finished..then the screen blank....
    Sent from my GT-I9000 using Android Tablet Forum App
  4. el_tako
    el_tako Member
    NULL
    I have the same problem I tried all sorts of combinations with the buttons but nothing has worked, I have understood that in other models can be connected to a PC and I've tried with an ipod cable, which is of the same input, but hard I try I failed to do which recognizes the tablet. Likewise, I have sought ways to contact the manufacturer to give me a solution but it seems to be no way to locate because the manual does not include any information about the manufacturer or the type of problems. If anyone knows another method to revive the tablet please let me know
  5. ricosan
    ricosan Member
    wow.....we should start a club. the dead droids...i too have the same sort of dilema......different model same sort of outcome
    here is where i am now any help would be appreciated.....
  6. TabletUser6680
    TabletUser6680 Member
    USA
    Mid Tablet PC w/Android 2.1 OS
  7. familiozo
    familiozo Member
    bulgaria
    ly 706
    I have the same problem BLACK SCREEN any solution???
  8. rodrigojob
    rodrigojob Member
    CPU VIA 8505+ Generic
    i am other aPad bricker :)
android dead during firm ware installation
android tablet died during firmware update
android tablet error dead
flash tablet failure
how to flash dead android devise firmware with out pc
solution android smarbook wm8505 dead after flash
tablet md 706 be display light jumper solution
what to do tablet flash failed
wm 8505 dead no booting
wondermedia 706w firmware
