Flytouch (I think) bricked, please help
Discussion in 'Gome Flytouch Problems' started by rh072005, Apr 21, 2011.
  1. rh072005
    rh072005 Member
    Apr 21, 2011
    I tried to update the ROM on my tablet this morning and I'm pretty sure I've ended up bricking it.
    It's a 7" MID tablet, with a red charging light, blue power light and green headphone jack.
    When I turned it on it flashed straight from blue to red. After doing this a couple of times the blue light now stays on when it turn it on but the screen stays black. I've tried loading on new ROMs but it won't do anything. Can anyone help me with how to unbrick it and then also what ROM would be best to load on to it afterwards (preferably android 2.2). The specs I got when I bought it are as follows:
    CPU: VIA 8650 (800MHZ)
    OS: Android 2.2 - this turned out to be the dodgy chinese one, hence the new ROMs
    RAM: Htunda 256 DDR2
    NAND Flash: Sansung 2GB FAT
    Screen: 7"
    Here's the full info
    7" Epad Android 2.2 WiFi 3G Tablet PC MID Touch Camera on eBay (end time 12-Apr-11 22:27:05 BST)
    any help would be much appreciated
    p.s. also if anyone can identify exactly what model I have that would be awesome
  2. Raymond_the_Red
    Raymond_the_Red Member
    Apr 26, 2011
    GardenCity, KS USA
    Pandigital Novel 7" 2GB & 4GB, Generic 7" Flytouch Blue LED
    OK, let me try to ID it.
    The Blue LED and Green headphone plug are common with the generic clone of the GOME Flytouch 1.
    These generic models had the same four holes for each of the speakers that was on the original Flytouch.
    The volume controls, power button, power plug, headphone, USB/eithernet dongle, and micro-SD would also be in the same placement. That is probably where the similarities to the original end.
    The fact that it was listed as MID is good if it’s also printed on the box.
    I’ll stop and let you say if your tablet looks like that. If so I’ll continue, you might be interested more.
