help after factory reset please
Discussion in 'Ployer Momo Tablets' started by ianh, May 31, 2013.
  1. ianh
    ianh Member
    plymouth, uk
    ployer momo9
    Hi all. New to the site and thankful for the advice therein. Despite searching I still need some help.
    My 12yr old daughter has a white case/black screen Momo9 which was displaying an error and wouldn't go past the screen displayed.
    It's 5 months old.
    Used the reset button at the back.
    After managing to get it powered on (don't know how - power and vol+ buttons I think) it displayed a screen that allowed me to do a 'factory reset'. Although it allowed me to do this, I was still getting a new error message saying 'unfortunately email has stopped'.
    After resetting, the player will no longer turn on. Tried everything previously including the power/vol+, reset and power button with no luck.
    To paraphrase - I have a dead tablet.
    Is it saveable? Am I missing something?
    Ian
  2. hydeparker
    hydeparker Member
    GUERNSEY
    MOMO11
    Hi, I may be simplfying things but are you sure it is still charged? If you plug in the charger and the battery is showing Red that could be the problem, leave pluugged in until it goes green.
  3. ianh
    ianh Member
    plymouth, uk
    ployer momo9
    thanks for your reply. I'm not sure how to tell if it's charged or not, because I can't turn it on. I'm going to leave it on charge overnight. I had managed to switch it on, but it would not progress past the white screen with the writing in the middle which includes the words 3D. At one stage we left it on that screen for ages to see if it sorted itself out, but it didn't. It was not turning on consistently, but would turn off straightaway. My daughter says that it has always taken a while to load. Is that right? Also, what should I expect after doing the factory reset? Should it turn on as normal?
  4. ianh
    ianh Member
    plymouth, uk
    ployer momo9
    thanks for any help you can give
    Ian
  5. Spider
    Chicago, IL
    Someone with a similar problem got it to turn on by holding the power button in for a very long time, like over a minute. Might work if you haven't already tried it.
ctronic taplet hard reset
ctroniq tab screen not working
ctroniq tablet hard reset
how to hard reset ctroniq tablet
how to hard reset momo12 player
how to hard reswt ctroniq tablets
how to mo mo tablet recovery
ployer momo 19 reset
restart momo tab
restart tab ctroniq
