Help android market problem
Discussion in 'Android Tablet Q&A' started by xRookie, Sep 16, 2011.
  1. xRookie
    xRookie Member
    Singapore
    MID tablet
    Erm can anyone help me why when i slide down the android market app den below empty slide down is empty HOW HOW :confused: CAN ANYONE HELP PLS REPLY ASAP THANKS
  2. DanU
    DanU Member
    Dallas
    WITSA91
    Did it ever work properly? If not you may not have full market access. Check Youtube for a procedure to clear cache in Market and clear data in Google Framework Services and reboot to resolve the problem (at least on some devices). Search on A81E Market Fix or something like that. I had a similar issue with my WITSTECH A81G and it worked very well.
    Good luck with it.
