Help, don't know how to use my epad
Discussion in 'New Member Introduction & Forum Website Assistance' started by jankni, May 21, 2011.
  1. jankni
    jankni Member
    nanango,queensland,australia
    epad
    I purchased an ePad and don't know if I did the right thing, have to work out how to use it as the instruction booklet i received doesn't help much. Mainly wanted a ebook reader, :confused: have i done the right thing
  2. DarkHalo
    DarkHalo Senior Member
    Epad Android 2.2 7in Tablet
    I also just purchased an Epad and one of the uses I had planned for it is also as an ebook reader. I went to the included 'App Market' (icon is on desktop) and installed the Kindle reader. I've not purchased any books for it yet but Ive done a dry run thru the process and it seems very straight forward. The install process for the Kindle Reader only took a couple of minutes.
    Also if you install 'share app' and 'apkshare' from the App Markeplace it will take you to another site with a LOT more android apps for your Epad. Good luck!
    on edit: Thinking back I read that actual requests for help are supposed to be posted in other parts of the site. This section is for intros only. My apologies. I should have looked closer before replying.
how to use android e-pad
how to use new epad
how to work an android epad
how to work e-pad
