Help! Forgot Unlock Pattern!
Discussion in 'Pandigital Novel' started by Emscookie, Nov 12, 2012.
  1. Emscookie
    Emscookie Member
    Tobyhanna, PA
    Pandigital Supernova DLX
    How do I reset my sign in pattern on my pandigital supernova DLX?
  2. Spider
    Chicago, IL
    Moved to the Pandigital forum.
  3. Frederuco
    Frederuco Super Moderator Staff Member
    /EARTH/USA/NC/
    ASUS TF101
    There are 2 ways:
    Option 1 - (works if your tablet is connected to the internet) attempt your pattern or PIN 5 times and fail. If using a pattern, must be 4 dots to be considered an attempt. Then it will prompt you to login with your Google Account to reset your PIN/Pattern. This only works if your WiFi is on and you are near an access point you have previously connected to.
    Option 2 - Factory Reset (wipes the tablet clean). This method you will need to find out how to use the hardware buttons in combination to do a factory reset. It may be in the manual, or you may have to call the OEM to ask how to do it.
forget my twintab pattern
forgot pandigital unlock pattern
forgot password on pandigital supernova
hard reset pandigital supernova
hard reset twintab
how to reset my pandigital supernova
how to reset pandigital device
i forgot my password on pandigital-supernova
twintab android tablet hard reset
twintab how to unlocke pattern
