After a faulty wondermedia W8650 , I end up buying a Superpad II on Ebay , and aside from the software issues which I have been able to work around on a cse by case, I have a Hardware Issue that is bothering me, The Slots for for the SD cards will not hold the card in when i put it , the card will come back out , and the only way I can use the card is if I hold it in with my finger while I AM using it which is not very practical. does any one has had the same problem or hear of , and could share any solution?
thank you !
thank you !
