Huawei S7: Auto boot up when plugged in / How to change the battery charging screen?
Discussion in 'Huawei Ideos S7 Slim Technical' started by pegtop, Mar 6, 2013.
  1. pegtop
    pegtop Member
    Hungary
    Huawei S7 Slim 201u, Overmax DualDrive
    Hi there,
    I have a Huawei S7 Slim 201u, which I would like to build in to a car dash. My target is that the tab will turn on automatically when the ignition is on. I used to have tasker app for this, but that can only wake up the device from sleep mode, which still drains the battery. I found the solution in some samsung forums, they changed the battery charging screen to a reboot script. So, when the tab is turned off and you plug it, ideos screen appears, than instead of the battery charging screen, the tab will boot up. Unfortunately I cannot find the file for battery charging animation on this device. Can you please help me of this, or do you have any other suggestions to succeed? Thanks a lot in advance!
  2. pegtop
    pegtop Member
    Hungary
    btw, it is a rooted tab with CM10 ROM. Thanks again for any helps!
acer autoboot - boot on charge
android auto boot on charge
automatically boot phone when charging huawei
boot on charge huawei
how to boot huawei tablet battery
how to get huawei tablet s7 to boot up
huawei auto boot when charging
huawei autoboot
huawei autoboot charger
huawei boot charging
huawei charger script
huawei s7 always have charging icon
huawei s7 battery and charger
huawei s7 car charger
hw 2 charge hauwei s7 tablet
my huawei ideos slim7 tab is charging slow slow
my huwawei boot up when plug in
