Huawei s7 slim does not shut down properly and then won't start up
Discussion in 'Huawei Ideos S7 Slim Technical' started by Stephen.Holness, Aug 29, 2011.
  1. Stephen.Holness
    Stephen.Holness Member
    South Africa
    Huawei S7 slim
    Hi, I have just got a Huawei Ideos S7 Slim and enjoy the overall use of the tablet. However, when I try to shut down the tablet via the power-off button (and then selecting the shut-down option), the tablet only appears to half shut down. The screen goes black, but home and menu buttons stay very slightly backlit. From here I can't do anything. If I push or hold the power button, the backlit buttons briefly get brighter, but the tablet does not turn on. The screen is unresponsive. All I can do is briefly remove the battery. Once I have done this, I can start the tablet with the power on button an it seems to work fine, until the next time I try to shut it down when the strory starts again. Some questions:
    1.) Am I being stupid and missing something obvious?
    2.) Is there some solution to this problem (perhaps alternative shut down app?)?
    3.) Is this a hardware problem or an app problem (The tablet is new, and only has a few extra apps added)?
    Please help!
  2. bladerunn3r
    bladerunn3r Member
    Fort Worth
    Acer Iconia a100
    To answer your question: No, you aren't missing anything, this is a fairly common defect (hardware problem) these devices have (as evidenced in the forum complaints). As far as I know, the only way to deal with it is to do a battery pull.
    Unfortunately these tabs are sort of pieces of crap. I really liked mine, but I had a host of reoccuring hardware problems that many other purchasers like you have or had. They all got worse over time and increased in frequency. Mine rarely did that (turned off with lights still on) when I first bought it; but it happened more and more often over time, always requiring a battery pull. I had mine shut off properly for a week. Then I turned it on a week ago -- and nothing. Won't turn on. Lights flash and haptic feedback buzzes--simultaneously--every few seconds -- as if it is trying to turn on, but can't. I wanted to send it to Huawei under their warranty, but I have no idea if they will honor it, or what their remedy would be, or how long it will take. Further, since I can't turn it on, I can't erase all my personal account information (gmail, facebook, etc) before I send it in. So I trashed the thing. It was a fun couple of months, but in the end I really regretted the purchase, since it was a total loss for me.
    Sorry to be such a downer, but I would strongly recommend returning this tab it you can -- or AT LEAST exchanging it for another, as it doesn't appear that ALL purchasers have this defect; only the unlucky ones.
    Good Luck
  3. Stephen.Holness
    South Africa
    Huawei S7 slim
    Thanks for the response - I least I know I am not being a total moron!
  4. JMarty
    JMarty Member
    Hungary
    S7 Slim
    Hi!
    I had the same thing. I did a hard reset. It solved my problem
    Marty
  5. 0ns
    0ns Member
    Mexico City
    Huawei IDEOS S7
    It just happened to me, i read your post and i thought "Damn, i have a brick"... but i did this following steps and my ideos is working again...
    1.-take the battery of the tablet.
    2.-Connect the tablet (without battery) to the AC adaptor.
    3.-It´s going to turn on as it would normally.
    4.-Once it´s on, you can work on it, or delete your personal info... at this point i placed the battery on the tablet (while connected and running), 2 minutes after, the battery started charging...
    5.-I waited to full charge and well, it´s working again.
    Maybe we shouldn´t left the battery depleted.
    Hope that this info helps someone. It worked to me. And maybe if you still have your device you can sello it, or give ir to a younger brother, or children.
hawai ideos s7 skype doe
how to turn off huawei tablet
huawei not shut down
huawei s7 power on and off
huawei s7 tablet troubleshooting
Huawei tablet shut down
ideos s7 how to close everything that i open
my huawai tab is not open always rebot problam
shutdown when unplug the power adaptor huawei ideos s7
what to do when ideos huawei slim 7 does not charge
