In need of help/advice
Discussion in 'Froyo' started by Twisztedjester, Apr 22, 2012.
  1. Twisztedjester
    Twisztedjester Member
    Georgia
    android 2.2 tablet android mid 800003, samsung stratosphere
    I recently purchased a 8" tablet for my boss its running 2.2 with a honeycomb mod unfortunately skype isnt supported for this version and thats main reason he wants it {hes from italy} im going to list the tech specs and am in need of advice if its upgradable to a different version of android or if im screwed
    Android Mid 80003
    Processor: VIA WM8650 High-performance 800MHZ CPU+300MHZ DSP
    Frequency: 800Mhz
    OS: Google Android 2.2
    Memory RAM: 256MB
    Flash Memory: 2GB (1GB Free) (Expandable by MicroSD to 32GB)
    WiFi: 802.11 b / g
    3G Function:
    - TD-CDMA:TD368
    - WCDMA:Huawei E220/E230/E160X/E169G/E1750
    - Alcatel X060S/X200
    Speaker: Built-in Speaker 8/1W
    Camera: Built-in 3MP
    Reset hole: Hidden (reset function)
    Buttons:
    - Top of the key: Power Key
    - Positive primary key: ESC
    - Right button Volume control Keys + Menu button
    Display Resolution: WVGA 800 x 480 Pixel
    Size: 8 inch TFT 16:9
    Touch Screen: TFT Resistive Touch Screen (two point touch),achieve pages and images zoom in and out
    Card Reader Slot: T-flash card (Support up to 32GB)
    Sound effect: - In focus Audio
    - Built-in stereo speaker
    - Built-in Microphone
    Supported Media Formats:
    Audio: MP3,WMA,WAV,AAC
    Video: [MPEG1/2/4,MJPG,H263](1280×720) resolution,H264 (720 × 480) resolution.
    Battery: 2500mAh, 7.4V
    Gravity Sensor: 4-Dimensional gravity sensor
  2. userbe1155
    userbe1155 Senior Member
    plymouth
    wm8650
    Try uberoid v10.1. I had a7" tab with wm8650cpu tho' mine did support skype I never used it. You'll find plenty of info on the wondermedia based pages of this forum. It can be time consuming if you're not sure of tab specs or model number but persevere its worth it in the long run. This version of uberoid supports honeycomb & worked well on my tab. There are newer versions but I had trouble updating. My errors probably so I stuck with v10.1 & had no troubles. Read carefully what you have to do & you will have a better device for sure.
