killed battery ??
Discussion in 'Android Tablet Q&A' started by b larnick, Dec 13, 2014.
  1. b larnick
    b larnick Junior Member
    de
    linsay F10XHD4CORE
    I plugged a linsay 10XHD4CORE into usb port into my hp pc to charge, now the only thing that comes up is a blk battery with a yellow triangle with an explanation mark in it ? did I kill my battery?
  2. b larnick
    de
    linsay F10XHD4CORE
    nothing, I just needed to know is there something I can do before changing the battery ??
  3. Spider
    Chicago, IL
    Hi b larnick, welcome to the forum. Nice to have you as a member of Android Tablets. I don't think you hurt the battery by what you did. However, I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck
