Locked out - need hard reset
Discussion in 'Android Tablet Q&A' started by DJC2012, May 19, 2012.
  1. DJC2012
    DJC2012 Member
    Indiana
    m1050s
    Purchased a Kocaso 1050s tablet off ebay. I think I hard reset the device but I am still be prompted for a user name. I tried USB connection to PC but device is not regconized. Ideas appreciated - believe OS is 2.3
  2. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Can you get the User Name from the Seller?
  3. DJC2012
    DJC2012 Member
    Indiana
    m1050s
    Trying; but, so far no luck. Would like to factory reset.
  4. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Unless you can access Settings you will need someone to tell you how to do a "Button Reset".
  5. DJC2012
    DJC2012 Member
    Indiana
    m1050s
    Right, I used sequence for another model power off, power+menu, release power upon startup and release menu on adroid icon. It seems to reboot differently and the date was reset but, still being prompted for username.
  6. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Possibly not the right sequence for your tablet.
  7. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Just a thought, have you tried the screen name of the seller?
  8. DJC2012
    DJC2012 Member
    Indiana
    m1050s
    Good thought, tried it, no luck.
  9. i1ikecandy
    i1ikecandy Member
    Asus Transformer
    You should be able to hold the power button down and the volume up (left side closest to power button) and it should bring you to a system screen that gives you the option to do a factory reset. You would use your volume buttons to scroll up and down and the power button to select. just scroll down to data wipe/factory reset and it should work.
    goodluck.
  10. marshaanton1
    marshaanton1 Member
    Flytouch 10vc
    reset buttton?
hard reset kocaso m736
how to hard reset kocaso m736
How to reset a kocaso tablet
How to Reset Kocaso Tablet
kocaso m1050 hard reset
kocaso m1050s factory reset
kocaso m1050s hard reset
kocaso m736 factory reset
kocaso m736 hard reset
kocaso tablet m1050s hard reset
