Momo 11 Speed Locked by Accident, How to Unlock?
Discussion in 'Ployer Momo Tablets' started by valwizard, Oct 29, 2012.
  1. valwizard
    valwizard Member
    UK
    MOMO ployer 11 speed
    Hi to everyone! Just got an android tablet Momo ployer 11 speed. After few attempts to unlock it, I got a screen " To unlock sign in with your Google account, username, Password... " But how the hell I could unlock it if the internet is off and tablet is not responding to any commands? I tried to reset it pushing the reset button on the bottom, but it doesnt help. Could anyone help me, please? I dont want to give up.
  2. valwizard
    valwizard Member
    UK
    Very usefull forum
  3. J515OP
    Northern CA
    Did you even try searching? This is a common question on the forum and you would have found lots of answers. The forum is only as good as you let it be.
    You need to factory reset your device. Search this forum or google for "Factory Reset MOMO ployer 11". This is usually accomplished by by powering the device up by holding a combination of buttons such as power and Vol + at the same time then selecting reset fromt he recovery menu. Oh and don't add a password to your device in the future.
    • Like Like x 2
  4. valwizard
    valwizard Member
    UK
    Yes, I did. I know that I need to reset to a factory defaults, but this doesn't help. The problem is common and this should give a kick to improve their product. If you give the opportunity to enter your account, then give the opportunity to enter to the internet. Otherwise its useless. Thank you for attention.
  5. J515OP
    Northern CA
    Yes, the standard procedure for unlocking with a lost password is that an email will be sent to you gmail account associated with the tablet after a certain amount of attempts have you checked their? This sounds like the part you are saying is not working. After that a factory reset should work but you need to search how to accomplish that for your specific device. A factory reset is different than a pin hole reset. A pin hole reset (pushing a little button hidden in a tiny "pin hole") is about the same as rebooting and will clear freezes and those sorts of issues. A "factory reset" is accomplished by entering a recovery menu through a certain button combination at boot up. From here you can completely reset the tablet to factory condition without a password.
    I hope you figure it out, I am sure it is possible.
    JP
  6. MOMO11SpeedUK
    MOMO11SpeedUK Member
    UK
    MOMO11 II/Speed, NATPC M009S HD, Acer Iconia B1, NOOK Simple Touch Rooted
    The easiest way I'd recommend for you is via ZhuoDashi.
  7. valwizard
    valwizard Member
    UK
    Thanks to everyone but the problem remains. I just try to send it back to seller and forget about these things. How many times I am saying to myself Do not by cheap things ! ZhuoDashi. doesnt work
  8. stevebarber
    stevebarber Member
    United Kingdom
    ployer momo 11
    this reply doesn't help - if you can't get past the lock screen, you can't get to the factory reset option.
cara unlock speed tab
deblocage de la tablette ployer momo11
hard reset momo ployer
how to factory reset ployer momo11 tab
how to recover a password in ployer momo speed 11
howto unlock ployer momo 11 speed from pin
momo 11 speed forgot password
momo lock
momo tablet pattren lock how to remove
momo tablet to many pattern attemp
