Hi everyone,
after a few months using my 7022 Kyros I decided to root it. I did it with SuperOneClick 2.3.3. Aparently, everything went good, but I´m not able to change LCD density, the app Mount /system (rw / ro) simply doesn´t work, although it shows a message that the system has been successfully mounted to r/w. When I try to edit build.prop at /system it says a error had occured. Even though the apps appear as authorized in SuperUser. I read somewhere that the rooting might not be FULL.
Is there any way to make sure the root works? There are several apps I need to install but can´t due to the incompatibility deed.
Tx a lot in advance.
