Need some clarification on features and rooting
Discussion in 'Coby Generation 1' started by LaughingCheese, Jan 22, 2011.
  1. LaughingCheese
    LaughingCheese Member
    Hi all,
    Found this forum from googling about rooting the Kyros.
    I've been trying to understand if rooting means that I can install Android 2.2, or, since its an embedded device, am I stuck with 2.1 ?
    This line from wikipedia has me really intrigued:
    http://en.wikipedia.org/wiki/Rooting_%28Android_OS%29
    Is that accurate about the Kyros ?
    Also, does it support ad hoc connections ?
    LC
  2. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    There is some work being done on updating the kyros by myself and others. Cyanogenmod has an version for the tablet, but I don't think anyone had finished a kernel update yet
  3. LaughingCheese
  4. probbiethe1
    Gilbert, Arizona
    if you can wait for a tablet running gingerbread (2.3) you might as well just wait for a tablet running honeycomb because honeycomb is suppose to be even better and actually made for tablets
  5. LaughingCheese
    True I guess. Depends on the price. If the 2.3 is cheaper I'll go for that.
    Also, still waiting for clarification on ad hoc connections.
    LC
