Noob in need of help
Discussion in 'Acer Iconia Tab A500 Forum' started by miked71, Aug 18, 2011.
  1. miked71
    miked71 Member
    iconia A500
    hi guys,
    Only had my tab a couple of weeks,
    my question to you good people is,
    when reading emails on my aol account, i need to open zip file attachments from a trusted source, but keep getting malicious spyware message saying can't save or open.
    Is there anyway around this as i need to open these attachments
    any info gratefully received :)
    Mike
  2. dan776
    dan776 Member
    acer iconia a500"
    Hey Mike,
    Did you find a solution to this?
    I'm not sure what advice to give, but if it were me I would first try to forward the message from AOL to your Google Account, and try it through there?
    Otherwise, you could install "Dropbox" on a PC and on your Tab, and unzip on your PC and use Dropbox as a shared folder... the Dropbox solution has helped me tons for various reasons.
  3. miked71
    miked71 Member
    iconia A500
    Hi Dan
    Thanks for the reply
    Not got anything sorted yet,
    going on holiday next week so will be away from my pc and need to open these zip files, on my Tab, while we are away.
    Will give the Google account route a go to see if this works.
    Thanks for the heads up
    Mike
  4. miked71
    miked71 Member
    iconia A500
    Just spoke to Acer tech guys, they said that Android will not let you open zip files of any sort trusted or not, including unzipped files.
    Files have to sent as xls files to be opened.
    Hope this helps anyone in the future.
    Mike
  5. Icebike
    Icebike Senior Member
    They lied. (Unfortunately this is becoming common with Acer Support.)
    Go to the market.
    Download ES File Explorer
    Install. This will open any zip file you have on your Tablet, and optionally extract it to any directory you choose (long press).
    Sometimes you have to fight with the web browser to get it to save attachments, (if you read your email in a browser). Try Dolphin for Pad from the market. Works fine. Opera works better for this (also free). Stock Browser seems to want to save Zip files under strange names (especially if you use Gmail).
    Gmail app won't save zip files.
    K-9 mail (free in market) will save them just fine.
can android tablets unzip arj files
