Hello, I have a Sylvania 7" tablet that was working fine until a few days ago when I turned it on it would go to the tmic screen and no further. I've tried to do a factory reset but it just will not reset. Does anyone have advice for me short of trashing it? Thank you
Hello Simon, try resetting again using some of the methods you'll find in the link below. Good luck! First try turning the tablet completely off for a minute and then turning it back on. (Hold the power button in until you get a shutdown message and select shutdown.) Factory reset: How Do I "Factory Reset" My Tablet? If there are no instructions there specifically for your tablet, try some of the methods for other tablets. One of them will probably work and you won't hurt anything by trying.
Thank you Mr. Spider, I've tried every combination in that list and it still week not get past the Infotmic screen. I'm stumped
So nothing else huh? My tablet is the only one that has done this and there's no cure huh.... THANKS PEOPLE
