Please help me!!!! :(:(:(
Discussion in 'Other Platforms' started by pisto890, Dec 24, 2010.
  1. pisto890
    pisto890 Member
    Hi every one, yesterday i've bought a new multimedia tablet called TM700 by r.t.works.....
    is has android 1.5 and i want to update the firmware to android 2.2 but i can't find new firmware for this product!!
    how can i do??
    thx 4 the answ
  2. gurgle
    Near 39.11°N 94.6°W
    That is likely due to two primary reasons.
    1. The manufacturer/vendor did not create a firmware for 2.2 with your chipset or tablet.
    2. Your chipset or tablet cannot handle any version past 1.5.
    There are so many off name tablets. yours may have another name. Look at your settings and system information. Describe or screen capture your details. There might be a compatible firmware but I do not want to give hope.
    You may have only 1.5 as an option
  3. Anllie
    Anllie Member
    MADRID
    TM700 r.t.works
  4. belgacom2
    belgacom2 Member
    belgium
    hello - i also bought the i.t.works tm700 and also am searching to update android 1.5 to 2.2 version. as i did not find i asked in the shop i bought it and they told me there is no problem to update - i have to return there with the device and immediately i have the answer i inform you. so keep hope.
  5. squat251
    squat251 Member
    that cannot be upgraded beyond possibly 1.6 sorry, but its too weak
it works tablet tm700
it works tm 700 tablet
rt works multimedia tablet
tablet itworks tm700
tablet itwotks tm700 7
tablet tm-700 firmware
tm 700 android update
tm700 tablet android update firmware
