Power light flashes - White screen on boot
Discussion in 'Gome Flytouch II' started by nitzereb, Mar 12, 2011.
  1. nitzereb
    nitzereb Member
    flytouch 2 wowpad
    Hi, I think I now own a brick, Bought it in november has worked ok til now..have done all the official updates....havent touched it since Jan...pulled it out to charge it...red led now flashes after a few minutes...when I attempt to boot..it only goes to a white screen and then shut down..have used all keys combos to reset/flash.nothing works just a white screen then off..is this a possible symptom of a dead/faulty battery?. i would think it would boot while plugged in, but no luck.. willing to disassemble..but this one does not have the screw holes along the case..do I pop up the screen?
  2. Macflame
    Macflame Member
    Sheffield, South Yorks, UK.
    MID701 and Archos 5
    Hi. I have a flytouch clone which shows the same symptoms. I flashed it. All went well, no error messages. Rebooted white screen.
    I have a number of apads, epads and have never seen this before.
    Is this the screen of death for Android tablets?
  3. SmaRkieS
    SmaRkieS Member
    Cebu City Philippines
    SuperPad 10.2
    Try the MicroSD flashing, it can be help.
    IF you are willing to open your tablet I have a guide.
    http://www.androidtablets.net/forum/gome-flytouch-ii/14255-inside-my-superpad.html
    Try to flash it with clean rom like 3245 room, using the MicroSD method.
  4. nitzereb
    nitzereb Member
    flytouch 2 wowpad
    If i plug in the ac adapter then i use the usb male 2 male and plug it in the second usb (close to hdmi) & to the PC.. hold down the power button (not letting it go).. the pad vibrates (buzzs) ....infotm logo...then the planet then it shuts down, I can get into the recovery menu as well, but i need to hold the power button I've put updates on the sd card but i get the message no recovery found ..try sd card..I'm thinking I have a defective battery or power adapter. I remember reading these won't boot unless the battery is charge..correct? I have tried the method above but it's not on long enough for the pc to see it. Any ideas?
  5. mushmush
    mushmush Member
    Sydney
    Superpad
    Hello nitzereb,
    I am having similar issue,
    Did you manage to fix this one?
  6. nitzereb
    nitzereb Member
    flytouch 2 wowpad
    Ordered a battery off ebay should be here (fingers crossed) after oct 20th, This is my last try on this tablet. my gut says it's the battery since these devices will not work unless the battery has a charge.
  7. nitzereb
    nitzereb Member
    flytouch 2 wowpad
    OK gang...The battery was the issue, I replaced the battery with the one from ebay. After letting it charge for an hour..it booted right back up as normal. So blinking LED light while charging = BAD Battery, and all the other attempts and their results from above = dead battery.
    link to batteries on ebay
    superpad flytouch 2 battery | eBay
    The one I bought, I paid for it on October 3rd and it arrived Oct 17 from China to NY
    OEM 3800mAh Battery For 10.2" ePad SuperPad & FlyTouch2 | eBay
    Hope this helps anyone else out there!
lenovo tablet no screen & flashing power light
lenovo tablet on charge flashed white screen then power dead
lenovo tablet screen flashes when on charge
superpad 3 powerlight flashing
tablet boots to white screen
tablet flashed white screen
vtab1008 white screen boot
