Problem installing applications on 2.2
Discussion in 'Telechips TCC8902 Tablets' started by Magnus, Jan 15, 2011.
  1. Magnus
    Magnus Member
    Denmark
    10" Apad from Propad.dk
    Alright, so i bought this 10" Apad from Propad.dk
    It's "born" with 4 gb HD, and can be extended to 32 gb (SD card).
    Since Propad shop didn't send the Sd card i ordered (it's comming monday - hopefully), im using the HD-storage at the moment.
    Well, i downloaded both "Easy Installer" and "Quick App Installer", and my problem seems to be that they don't find the .apk's that i put into the folder.
    Yesterday i tried with a few games and it worked perfectly, but now that i try some other apps it doesn't seem to find them, even though i put them in the same folder as the other games.
    Anyone? :)
  2. xaueious
    Canada
    Normally, I try to install any file manager (OI Filemanager, ES File Manager) and install by launching the APK file. I don't use Easy Installer or Quick App Installer.
    • Like Like x 2
  3. Magnus
    Magnus Member
    Denmark
    Alright, thank you. I'll try downloading a file manager :)
  4. Magnus
    Magnus Member
    Denmark
    Yep, works perfectly. :) Thanks alot!!!!!!
    Can't run DocumentsToGo on "this device" unfortunately :-( My chip is not supported lol.
how to transfer games on kurio 7s to sd card
