Problem powering up KLU
SParker2012
I got a KLU tablet on Black Friday and all of a sudden it wont power up. It's fully charged and I have tried numerous times. Any ideas?
leeshor
6,330
1,037
Welcome to the forum
I can only suggest 2 things. First a very long press on the power button. If that doesn't work plug it into a running PC for 5 hours or so and try again, (that's a special trick that sometimes works). Report back the results.
Spider
15,784
1,813
Hi SParker, congratulations on your new KLU tablet and welcome to the forum. Nice to have you as a member of Android Tablets. By all means try what Lee suggested, it often works. I'm also moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
