Problems installing SlideIt keyboard on my NC
Discussion in 'Nook Color Apps and Games' started by jinnijinn, Feb 17, 2011.
  1. jinnijinn
    jinnijinn Member
    SlideIt won't install successfully through the Market, so I found and downloaded the APK, sideloaded to my NC's SDcard (the root), then tried to move it to system/app. However, it won't move (or c/p), and I've tried Astro and File Manager. Astro just won't move it, and File Manager gives an 'insufficient permissions' error.
    Do I need a different file management app?
  2. avi
    avi Moderator Staff Member
    India
    Nook Color
    Why you're not able install slideit through market ? waht error you are getting ?
    Do one thing, connect NC via USB and copy the apk to SD Card, then use software like App Installer and see.
    and also make sure that, in Nook Color Tools, "Installing Non-Market Apps" is checked.
  3. faceman
    faceman Moderator Staff Member
    Pittsburgh, PA
    NOOKcolor on CM7 nightly w/ 1.1gHz OC
    Yes, you need a file manager that will allow you to change the system/app folder permission to Read/Write (R/W). Root Explorer is what I use, it's a paid app but well worth it for the simplicity of just such a task.
    Alternatively, you can use ADB. With the NC connected you can manually change the folder permissions (mount/unmount) and copy and push, etc. If you're not comfy with ADB, go for Root Explorer.
    • Like Like x 2
  4. jinnijinn
    jinnijinn Member
    Thanks much, faceman, Root Explorer looks like a bargain to me if it'll get the job done that easily. :)
    @avi, installing through market leads to a msg to install the app manually, and installing it from root using an installer app leads to a dead end; no error msg, but it just doesn't work.
  5. jinnijinn
    jinnijinn Member
    OK, Root Explorer moved the file (yay)...now how do I install it? Do I use an app installer, or use the 'extract' option in Root Explorer, or...?
  6. avi
    India
    Nook Color
    No try using an App Installer.
    I have Astro File Explorer and it does the job for me :)
  7. discothan
    discothan Member
    home
    Nook Color
    This is funny to me. Astro won't move the file because of its lack of Root Permissions, but it will install the app.
    Why can't someone just merge the two apps.
slideit keyboard licensing error
