Problems to setting up an apn
Discussion in 'Gome Flytouch II' started by Castiman, Nov 10, 2011.
  1. Castiman
    Castiman Member
    Bilbao, Spain
    Superpad Infotmic X210
    Hello... My name is Gonzalo, from Spain.
    I have a superpad with Infotmic x210, 256 mb...
    the firmware version is model number: InfoPad10; Android version: 2.2 v2.1;#3925; kernel version: 2.6.32.9; Compilation: FRF85B
    Apart from that i have a huawei e173 3g usb modem...
    When i enter in wifi connections -> mobile networks -> apn... there is no apn.. I press menu and select new one... i fill the info with my operator settings... press save... but nothing happens...no apn is saved... Tried with apn manager and created new apn... but in apn settings still is nothing... empty...
    What i have to do to create an apn and be able to see and use it...
    the 3g modem is connected but the light (green) shows it is in standby... when is connected is permanent blue.
    i think there is people who are using 3g modems with similar pads but dont know how they did it... no way for me
    Thx for your time and help and sorry about my english
  2. donc126
    donc126 Senior Member
    Singapore
    FlyThouch 2
    Your huawei e173 probably is not competable, they are recommending the huawei E1750, once you have connected with the huawei E1750, it will run automatically, no APN is require.
apn manager pro problem creating apn
apn not saving
apn set up help for android tablet
apn superpad 3
firmware to fix blank apn settings for android tablet
how to create apn in android wifi tablet i am creating the apn but it is not saving
how to save apn on android tablet
problem setting apn up
problems when creating apn
