QR Code Reader for Android?
Discussion in 'Vizio Tablets' started by TriplerSDMB, Feb 11, 2012.
  1. TriplerSDMB
    TriplerSDMB Member
    Visio VTAB
    Can anyone recommend a decent QR Code reader for the Visio VTAB1008 series? I deal with a lot of documents that have the QR code on them, and I figure that with the camera function on my tablet, could access their sites (or at least the "cloud drive" they're stored at. . .). Anyone use it and have suggestions?
    Thanks,
    Rob
  2. sabotank
    sabotank Member
    Coastal Georgia, USA
    Vtab1008, Vivotab Smart, Nexus 4
    i've always used barcode scanner. been good to me so far. however, i don't have it on my vtab so therefore i haven't tested it
  3. Conspirator
    Conspirator Member
    Wisconsin
    VTAB1008
    I have not found a single one that works with the VTAB. The reason I think they dont work is because the VTAB only has a front camera, not a rear facing one. The few that I have got to install crashed because when it called to load the camera, the system could not find the asset location of a rear facing camera. Crash report basically stated location of asset not found.
  4. cyorke
    cyorke Member
    Nashville
    EVO Shift
    There was a thread about barcode/qr readers awhile back. Supposedly there is a dev working one for tsblets with front facing cameras only.
    Sent from my VTAB1008 using Android Tablet Forum
  5. TriplerSDMB
    TriplerSDMB Member
    Visio VTAB
    Seems the front facing camera is the biggest hurdle to a decent program then. Thanks for the help!
    Rob
  6. Conspirator
    Conspirator Member
    Wisconsin
    VTAB1008
    Google Came out with one that works on the Vtab. Google Goggles It is not just for Barcodes, It will also do websearches on scanned objects.
    • Like Like x 2
qr reader for qmv7a tablet
QR SCANNER FOR ANDROID TABLET
