Question for Docs To Go Pro owners
Discussion in 'Android Tablet Apps' started by MaTaX, Aug 9, 2011.
  1. MaTaX
    MaTaX Member
    Acer Iconia A500
    So i need an app that will allow me to create and edit different types of files, right now I am in need of saving a doc file to pdf so I can use Brother Print&Scan to print it without having to go onto my computer and do it (not lazy just need it on the tab and in print so I always have it with me) But before I fork over 15 dollars I want to know if Docs To Go can infact save out a DLed .doc file and save it as a .pdf so I can print it?
  2. jrizal
    jrizal Member
    Los Angeles
    Maylong M-250
    No. Neither can QuickOffice. Try PDF Converter for Android.
  3. MaTaX
    MaTaX Member
    Acer Iconia A500
    Okay well I Dled it and it converted it but now the brother app says it's not in a supported format?
