SD card problems!!
Discussion in 'Augen Gentouch' started by skywalk2, Apr 11, 2011.
  1. skywalk2
    skywalk2 Member
    US
    Augen Gentouch 78 x 2, Nook, Nookcolor
    After having trouble putting it in, I had been using an old 256K sd card - when I inserted it, it was completely enclosed in the slot.
    I purchased 2 8gb sandisk sd cards (they say MicroSDHC if that helps any). I tried putting them in my 78's (I have two) but cannot get them in properly. I feel a click, but they stick out about 3mm. And the tablet will not read them at all. I cannot mount or format. I checked them in my nookcolor, and both the cards work.
    I had trouble with tablet 2 in that the card disappeared/fell into the tablet (I could shake it and hear it rattling around. I got it out with some creative thinking :).
    My other problem is now I cannot even get the 256 card back in the slot the way it was, or get it to read. What am I doing wrong here, or is this a fatal flaw?
    BTW - these tiny cards are annoying to work with!
    Msky
  2. husker_fan
    husker_fan Member
    Augen Gentouch78
    I had to play with my memory card a while before I figured out how to get it in properly. I thought I had it in the right way because it would click in place and was still sticking out a bit, but it would not read it at all. I tried it other ways and the only way that worked for mine was to have it click in and have it almost flush with the opening. I used the stylus to click it in and out.
    When I put my card in the slot it can go one of two ways, one way works and the other doesn't. Luckily I haven't lost my card inside of the device yet.
  3. UncleAl
    UncleAl Member
    Michigan
    Gentouch 78 v.1
    I had my card go in, and I got it out finally... but I have had little more luck with it.
  4. pharoah
    pharoah Member
    smsng g tab 3 8 inch
    the contacts on the card need to be facing the screen.
