[Solved] 7125 Display not timing out
Discussion in 'Coby Generation 2 Technical' started by Rossum, Feb 5, 2013.
Thread Status:
Not open for further replies.
  1. Rossum
    Rossum Senior Member
    Texas
    Craig CMP738b, Coby MID7015
    Just installed the Adobe Flash update from the Coby website. Everything seems OK, but now the display stays on no matter what timeout I set it to. Checked running apps, nothing. Changed back from live wallpaper to static, nothing. Anybody else seen this?
  2. Rossum
    Texas
    Solved!
    I had just installed Moboplayer, to play DVD VIDEO_TS folders--which it didn't do very well--and even though it wasn't running, the display would stay on. As soon as I uninstalled it, back to normal.
    Installed Daroon player, which works much better, and causes no problems. Yet....
Thread Status:
