The difference between a8 and apad
Discussion in 'Android Tablet Discussions' started by Annamm, Jan 9, 2011.
  1. Annamm
    Annamm Member
    Newbie here and looking for tablet toys, any recommendation would be appreciated.
    Found is quite hot on youtube. Is a8 is the upgrade for aPad?
    Android Tablet aPad: Android Tablet PC, MID, Wifi, 7" TFT Touch Screen ,HDMI output
    This great new Tablet PC is great for those who want to work on projects or e-mails while they're out and about, but don't want to carry around something as bulky as a laptop. This fantastic aPad has 256MB ram to handle multiple applications. You may use the device vertically or horizontally and it is perfect for viewing movies, reading e-books, listening to music, etc. Standby times is 3-4 days and usage time is about 3-6 hours depending on type of usage. Start ordering this aPad today from reliable electronics wholesaler **********.
    Highlights:
    * Wifi
    * 3G function
    * Compatible with WORD, EXCEL, POWERPOINT, PDF, TXT, etc.
    * Android os 1.6 Operating System. With your Google account, you can download a huge variety of free and paid software from the Android Market.
    * Support HD 1080P
    Manufacture Specifications:
    *CPU VIA MW8505 533MHz
    *256 MB Memory DDR2
    *1.3M Camera
    *Language supported: English, French, Spanish, German, Italian, Chinese over 30 countries languages
    *Screen, full-screen: 7-inch 16:9 wide-screen high-brightness TFT LCD
    *Resolution: 800 x 480
    *Touchscreen: full-size touch operation, sliding menus, icons and drag
    *Storage: Built in 2GB flash memory, support max up to 32GB Mirco SD card, with Micro SD card slot
    *Gravity sensor: automatically rotating the display screen
    *Connectivity: Wireless: 802.11b/g/n Wi-Fi CERTIFIED network connection
    *Audio: Supports stereo speaker unit, built-in microphone
    *Web browsing: Google chome-lite Browser UCWEB Browser
    *E-mail: Gmail
  2. ecargoonline
    ecargoonline Member
    China
    Hello, first i'd like to say that A8 is not the upgrade for aPad, it's actually an Apad with Cortex A8 Processor and 8" touch screen.:)
    As for your following mentioned tablet pc with android 1.6, i would suggest you to think twice before the purchase! Basically, i'd suggest every android tablet fan not to get a android tablet pc under android 2.1 OS.
    Actually, the A8 you metioned is a good choice! and here's the link for your refer: Android 2.2 OS 512 RAM with Freescale iMX515 Cortex A8 Processor Tablet PC M8003
    Good Luck!:eek:
